[gdal-dev] Re: KyngChaos Frameworks: GDAL's numpy vs Enthought's
numpy
Christopher Barker
Chris.Barker at noaa.gov
Wed Apr 21 12:17:35 EDT 2010
William Kyngesburye wrote:
> The problem is in Enthought's python, for using the retracted numpy, and they need to update their numpy (which could be a while if they don't want to use RC versions). I'm afraid I can't support using numpy 1.4.0.
Maybe you can follow: http://www.kyngchaos.com/macosx/build/gdal and do
it yourself. I assume you could use all the other Framework binaries for
the dependencies.
In fact, you may be able to re-build only the python bindings, and that
be as simple as running "python setup.py build", once you've made sure
that you've got your python using the right numpy.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
