[gdal-dev] kyngchaos Framework build doesn't support OGDI
Christopher Barker
Chris.Barker at noaa.gov
Wed Apr 21 19:29:39 EDT 2010
William,
I couldn't see a place to report this on your site, to I'm reporting it
here. The 1.7 GDAL build doesn't seem to support the OGDI drivers,
whereas the 1.6 build does.
I'm using ORG to read the VPF, as used by the NGA digital nautical
charts. Note:
$ /Library/Frameworks/GDAL.framework/Versions/1.6/Programs/ogrinfo
gltp:/vrf/Users/cbarker/Temp/DNC16/A1610880
yields:
ERROR 4: OGDI Driver doesn't support update.
Had to open data source read-only.
INFO: Open of `gltp:/vrf/Users/cbarker/Temp/DNC16/A1610880'
using driver `OGDI' successful.
1: buildngp at cul(*)_point (Point)
2: commp at cul(*)_point (Point)
Whereas:
$ /Library/Frameworks/GDAL.framework/Versions/1.7/Programs/ogrinfo
yields:
FAILURE:
Unable to open datasource `gltp:/vrf/Users/cbarker/Temp/DNC16/A1610880'
with the following drivers.
-> ESRI Shapefile
-> OGDI
So OGDI is in the list, but it doesn't work.
Note that I'm having trouble getting this to work with my own build,
too, so it may be a GDAL/OGR/OGDI issue, rather than an issue with your
Framework builds.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
