[gdal-dev] Error while Warping GTiff to EPSG3763
Franz Schiller franzschiller1975 at gmail.com
Tue Apr 27 10:04:33 EDT 2010
Greetings
I've been using GDAL for a while without any major issues or difficulties.
But, now I'm facing a difficulty with a gdalwarp operation. And i hope that
someone can help me or giving me a few tips:
I'm trying to do this: Converting a Geotiff to a EPSG 3763 (Portuguese
Coordinate system)
gdalwarp -t_srs 'EPSG:3763' ROI_QB_MUL_2.tif out.tif
And I get this:
ERROR 1: Too many points (441 out of 441) failed to transform,
unable to compute output bounds.
If I do gdalinfo ROI_QB_MUL_2.tif I get:
Driver: GTiff/GeoTIFF
Files: ROI_QB_MUL_2.tif
       ROI_QB_MUL_2.tfw
Size is 893, 567
Coordinate System is:
GEOGCS[,
    DATUM["unknown",
        SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
    PRIMEM["Greenwich",0],
    UNIT["metre",1]]
Origin = (2.395715062070880,48.813901970760220)
Pixel Size = (0.000035468073200,-0.000024505752140)
Metadata:
  TIFFTAG_XRESOLUTION=100
  TIFFTAG_YRESOLUTION=100
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (   2.3957151,  48.8139020) (  2d23'44.57"E, 48d48'50.05"N)
Lower Left  (   2.3957151,  48.8000072) (  2d23'44.57"E, 48d48'0.03"N)
Upper Right (   2.4273881,  48.8139020) (  2d25'38.60"E, 48d48'50.05"N)
Lower Right (   2.4273881,  48.8000072) (  2d25'38.60"E, 48d48'0.03"N)
Center      (   2.4115516,  48.8069546) (  2d24'41.59"E, 48d48'25.04"N)
Band 1 Block=893x1 Type=Byte, ColorInterp=Red
Band 2 Block=893x1 Type=Byte, ColorInterp=Green
Band 3 Block=893x1 Type=Byte, ColorInterp=Blue
Any tips of what to do? thank you so much
Franz
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100427/172df865/attachment.html
