[gdal-dev] 4 point, projective warping
John Donovan j.donovan at virtalis.com
Mon Aug 2 04:53:17 EDT 2010
I'd be very interested in a native GDAL implementation of perspective
warping. I've done something similar to the work Manuel has done on
Qgis, having written an in-house application that uses GSL/CBLAS. So I'd
be happy to help where I can, but as Manuel says, writing robust SVD
routines is beyond my ken.
So is another dependency the way to go?
-JD
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jeffrey Warren
Sent: 01 August 2010 21:54
To: Manuel Massing
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] 4 point, projective warping
Thanks for all the input, Manuel - I've gone ahead with the ImageMagick
system and it works pretty well. That said, a projective warp would be
great as a native GDAL feature, so thanks for the offer.
If anyone else has interest, please pipe up! If it's just me then I
guess there's not too much demand.
Jeff
On 7/30/10, Manuel Massing <m.massing at warped-space.de> wrote:
> Hi Jeffrey,
>> I've thought about implementing a projective transform in the qgis
>> georeferencer, so if you're interested I'll let you know when I get
>> around to it.
> If this interest you, I have just commited an initial implementation
> of projective warping (see
> https://trac.osgeo.org/qgis/changeset/13987)
> to the qgis georeferencer, which is based on the gdalwarper.
> In principle, it should be relatively easy to integrate this transform
> into a custom version of gdalwarp.
> Maybe there's even interest to have such a transform in GDAL proper?
> I would be willing to contribute the code to GDAL, although the model
> fitting step uses a singular value decomposition, so this would
> require some dependency on  a linear algebra package (I wouldn't
> consider it wise to reimplement numerical algorithms from scratch,
with their numerous caveats).
> cheers,
> 	Manuel
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
______________________________________________________________________
This email has been scanned for Virtalis Ltd by the MessageLabs Email
Security System.
This email has been scanned for Virtalis Ltd by the MessageLabs Email Security System. ______________________________________________________________________
