[gdal-dev] Geotiff with bands of different type
Martin Raspaud
martin.raspaud at smhi.se
Tue Aug 10 07:16:41 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Andrew Brooks skrev:
> On Tue, 10 Aug 2010 11:46:00 +0100, Martin Raspaud
> <martin.raspaud at smhi.se> wrote:
>> We have a satellite image in black and white, which show IR brightness
>> temperatures. The data is scaled between 0 and 255 for viewing, and
>> this is
>> packed in a geotiff file
>> Now some users would like to have the true value of the brightness
>> temperature
>> embedded in the file also.
> Maybe you can simulate something close by putting a scale and offset (slope
> and intercept) into the geotiff so you still display 8-bit values but a
> decent
> image viewer will also calculate the true values and give a pixel
> readout of
> the true value under the cursor. I say simulate because 8 bits may not give
> sufficient resolution.
Hmmm, that sounds like a sufficient solution indeed, very good idea, thanks.
Is there any scale/slope and offset/intercept tags defined in geotiff ?
Best regards,
Martin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJMYTUZAAoJEBdvyODiyJI4rOcIAJmI0PzHTOX7hHWD72NcnATG
KKgZFbGMtTL0rAGkexdqSv1fHsqGRL6Jp9QM+qi3Z/FFt6V6iNtlpiJX88k0Limb
aqRO61oHHf3tM0EbWfeSXe0dju/n9BkDiHpJ00k4kKVdyJ+7/7QlYNNHu1/4L+Xa
FO1Cm9X7eBHrq80PD0+oDNVq2D2epnj1EaiHCgiOpMiXZomf/4xs9AOVpG8aeJEf
tx06IO6wb18FuIZHk9mhu8nMqA4F+JEF9AZ0VXACvcDA8q17Q4PjngE0Mpba0tlg
vasSf9vJ/XCuNOOEGEq2lmE3Fp7Ec0ShTbuPBTNPHBKPhJKL4ffCyv7BXYtyUsc=
=3pgP
-----END PGP SIGNATURE-----
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100810/478a0f75/martin_raspaud.vcf
