[gdal-dev] RE: [GDAL_TRANSLATE]Problem with colorimetry
Tacot
cfab13 at hotmail.fr
Wed Aug 11 04:29:03 EDT 2010
Hi
First of all, Thanks a lot: it works!
I've run those commands line:
/*For all pictures => it's a little bit repetitive:
gdal_translate -of GTiff -expand RGB -co compress=lzw SC25_TOPO_0850_6470_L93.tif 0850_6470.tif
gdalbuildvrt truc.vrt *.tif
gdal_translate -of GTiff truc.vrt truc.tif
But maybe you can explain somme things to me:
- what version of gdal, reports the issue?
- What does the option RGB do?
- What is PCT2RGB?
Best Regards
Fab
Date: Tue, 10 Aug 2010 09:01:36 -0700
From: ml-node+5393675-1188735875-280951 at n2.nabble.com
To: cfab13 at hotmail.fr
Subject: Re: [GDAL_TRANSLATE]Problem with colorimetry
Fab,
I found the problem.
There were some differences in color tables of your images.
gdalbuildvrt application from the latest GDAL version reports the issue
when you try to build the vrt file. You're advised to preprocess your
rasters with other tools, such as pct2rgb.py or "gdal_translate -expand
RGB" to operate gdalbuildvrt on RGB rasters instead.
The reason the red areas were occuring in different areas is that gdalbuildvrt considers only the first file's color table.
On Tue, Aug 3, 2010 at 8:36 PM, Tacot <[hidden email]> wrote:
I think more about the value of data.
http://osgeo-org.1803224.n2.nabble.com/file/n5368754/PixelRed.jpg
But it's not always the picture on the right which pixels become red; it can
be also the picture on the left.
I have the felling it depends on the range of merging.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-TRANSLATE-Problem-with-colorimetry-tp5368059p5368754.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
[hidden email]
View message @ http://osgeo-org.1803224.n2.nabble.com/GDAL-TRANSLATE-Problem-with-colorimetry-tp5368059p5393675.html
To unsubscribe from Re: [GDAL_TRANSLATE]Problem with colorimetry, click here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-TRANSLATE-Problem-with-colorimetry-tp5368059p5411388.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100811/b5917f43/attachment.html
