[gdal-dev] ArcGIS 10
Hannes Reuter gisxperts at web.de
Wed Aug 11 13:19:59 EDT 2010
YES, numpy / gdal is under my Python 2.6/AG10site packages,
on the other hand, installing python, numpy, gdal, scipy is rather
straightforward and should be done in less than 10 minutes.. ;-)
The only problem I was running in -> Vista and Win7 maschines need the
newest version of gdal (larger than 1.6) to execute GDAL's readasarray,
while ogr is fine.. .otherwise they just die, while all is fine on XP
and linux. see
http://osgeo-org.1803224.n2.nabble.com/Gdal-Python-Win7-crash-with-ReadAsArray-td4398401.html
hannes
hth
> I hear the new ArcGIS10 has GDAL and NumPy built into the geoprocessor.  If this is true, does that mean that users will not have to install the various Python library bindings GDAL, numpy, etc. after a full Arc10 install?
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100811/5b8eebc1/attachment-0001.html
