[gdal-dev] No Interlis format support after recent svn update
Andreas Neumann
a.neumann at carto.net
Thu Aug 12 02:13:54 EDT 2010
Hi Even,
Thank you for your hints. It seems to work again. From all of your
suggestions it was most likely the make clean in ogr/ogrsf_frmts/ili. I
think all other things were fine (the HAVE_XERCES was set to yes,
ogr/ogrsf_frmts/ili existed).
Anyway, all fine now.
Thanks for your help,
Andreas
On Wed, August 11, 2010 7:11 pm, Even Rouault wrote:
> Well, interlis is listed for me with latest SVN, so I guess it must be
> some
> detail on your side.
> Did you do a full rebuild : 'make clean' and 'make' ?
> In GDALmake.opt, is HAVE_XERCES set to yes ?
> In the console, when compiling do you see that it goes into
> ogr/ogrsf_frmts/ili ? you can cd to that directore and make clean in it,
> and
> then retry a make from the top directory
> Le mercredi 11 août 2010 17:28:48, Andreas Neumann a écrit :
>> Hi,
>> For some reasons, after an SVN update, I can't use the Interlis format
>> anymore. ogrinfo --formats doesn't list the Interlis 1/2 formats as
>> supported.
>> Luckily I still have an older installation which I can use for my data
>> imports, but I would like to get it working again with the SVN version.
>> What could be missing? Xerces is listed as supported by the configure
>> script and ili2c.jar is also present in /usr/bin or in the jvm/lib
>> directory.
>> Any help/ideas would be much appreciated.
>> Thanks,
>> Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
