[gdal-dev] unable to append data to orale spatial
Imran Rajjad rajjad at gmail.com
Thu Aug 12 03:16:15 EDT 2010
hi,
I have appended the data but the -lco DIM=2 option does not seem to
make any effect, when I`m dumping records into my table, some of them
have sdo_gtype set to 3001 which is suppose to be 2001 and also an
extra Z cordinate is also appearing but I`m sure I have mentioned the
dimension, could there be a problem with the syntax here?
ogr2ogr -f OCI OCI:usr/pas at ip:port/db file.shp -append -skipfailure
-lco SRID=8307 -lco DIM=2 -lco GEOMETRY_NAME=GEOM -nln ASIA_POI
regards,
Imran
On Wed, Aug 11, 2010 at 11:50 AM, Peter J Halls <P.Halls at york.ac.uk> wrote:
> Imran,
> Imran Rajjad wrote:
>> Hi,
>> yes I figured that out, for now I just drop the index added initialy
>> and I append new data to the table, though I`m not very optimistic
> That is sensible: drop spatial index, update table, update SDO_GEOM_METADATA
> and recreate spatial index.  There was a related bug in ArcGIS a version or
> two back where the workaround published by ESRI was to do this same
> sequence!
> Best wishes,
> Peter
>> about not getting any more trouble when publish this table in
>> geoserver.
>> regards,
>> Imran
>> On Wed, Aug 11, 2010 at 11:25 AM, Peter J Halls <P.Halls at york.ac.uk>
>> wrote:
>>> Imran,
>>>  in the documentation for the OCI Driver it says clearly that the spatial
>>> extent and SDO_GEOM_METADATA entries are not updated when using append
>>> mode
>>> and that it is up to the caller to manage these.
>>>  It is actually quite easy to code for this, but does require an
>>> SQLExecute
>>> to handle SDO_GEOM_METADATA.  I simply generate this on the fly, along
>>> with
>>> the SQL to update the spatial index.
>>> Best wishes,
>>> Peter
>>> Imran Rajjad wrote:
>>>> Hi list,
>>>> I inserted a shape file in oracle 11g, now I have another shape file
>>>> with exactly same attributes, I`m using the -append option but it
>>>> seems the new shapefile wont get appended to the table, there seems to
>>>> be some problem related to the spatial index because data in both
>>>> shape files does not come under same spatial extent, is there anyway
>>>> to tell gdal not to create spatial index when data is being inserted
>>>> and when all the data has been inserted we create the spatial index
>>>> manualy?
>>>> regards,
>>>> Imran
>>> Peter J Halls, GIS Advisor, University of York
>>> Telephone: 01904 433806     Fax: 01904 433740
>>> Snail mail: IT Services, University of York, Heslington, York YO10 5DD
>>> This message has the status of a private and personal communication
I.R
