[gdal-dev] unable to append data to orale spatial
Peter J Halls P.Halls at york.ac.uk
Thu Aug 12 03:37:45 EDT 2010
Imran,
    is the initial table two or three dimensioned?
    Most of the shapefiles I've looked at have been generated by some ESRI
product or other ... In my experience, shapefiles are usually x-y-z-m, so three
dimensional geometry is a sensible default.
    It might be worth checking the OGR TRAC buglist ... I've a vague
recollection that at some version or other there may have been an issue
regarding appending a non-default coordinate dimension, but do not recall
whether that was ogr2ogr - which I use rarely - or an issue when programming
with the OGR API.
Best wishes,
Peter
Imran Rajjad wrote:
> hi,
> I have appended the data but the -lco DIM=2 option does not seem to
> make any effect, when I`m dumping records into my table, some of them
> have sdo_gtype set to 3001 which is suppose to be 2001 and also an
> extra Z cordinate is also appearing but I`m sure I have mentioned the
> dimension, could there be a problem with the syntax here?
> ogr2ogr -f OCI OCI:usr/pas at ip:port/db file.shp -append -skipfailure
> -lco SRID=8307 -lco DIM=2 -lco GEOMETRY_NAME=GEOM -nln ASIA_POI
> regards,
> Imran
> On Wed, Aug 11, 2010 at 11:50 AM, Peter J Halls <P.Halls at york.ac.uk> wrote:
>> Imran,
>> Imran Rajjad wrote:
>>> Hi,
>>> yes I figured that out, for now I just drop the index added initialy
>>> and I append new data to the table, though I`m not very optimistic
>> That is sensible: drop spatial index, update table, update SDO_GEOM_METADATA
>> and recreate spatial index.  There was a related bug in ArcGIS a version or
>> two back where the workaround published by ESRI was to do this same
>> sequence!
>> Best wishes,
>> Peter
>>> about not getting any more trouble when publish this table in
>>> geoserver.
>>> regards,
>>> Imran
>>> On Wed, Aug 11, 2010 at 11:25 AM, Peter J Halls <P.Halls at york.ac.uk>
>>> wrote:
>>>> Imran,
>>>>  in the documentation for the OCI Driver it says clearly that the spatial
>>>> extent and SDO_GEOM_METADATA entries are not updated when using append
>>>> mode
>>>> and that it is up to the caller to manage these.
>>>>  It is actually quite easy to code for this, but does require an
>>>> SQLExecute
>>>> to handle SDO_GEOM_METADATA.  I simply generate this on the fly, along
>>>> with
>>>> the SQL to update the spatial index.
>>>> Best wishes,
>>>> Peter
>>>> Imran Rajjad wrote:
>>>>> Hi list,
>>>>> I inserted a shape file in oracle 11g, now I have another shape file
>>>>> with exactly same attributes, I`m using the -append option but it
>>>>> seems the new shapefile wont get appended to the table, there seems to
>>>>> be some problem related to the spatial index because data in both
>>>>> shape files does not come under same spatial extent, is there anyway
>>>>> to tell gdal not to create spatial index when data is being inserted
>>>>> and when all the data has been inserted we create the spatial index
>>>>> manualy?
>>>>> regards,
>>>>> Imran
>>>> Peter J Halls, GIS Advisor, University of York
>>>> Telephone: 01904 433806     Fax: 01904 433740
>>>> Snail mail: IT Services, University of York, Heslington, York YO10 5DD
>>>> This message has the status of a private and personal communication
