[gdal-dev] unwanted error message
Fabrice LALLAURET - PSV fabrice.lallauret at external.thalesgroup.com
Fri Aug 20 03:33:00 EDT 2010
  Le 08/20/2010 08:40 AM, Chaitanya kumar CH a écrit :
> Fabrice,
> Can you pin point the code lines that are giving the error messages?
Oops, after compare the result of my script on several platforms (linux
with my compiled gdal/windows with my compiled gdal and fwtools) I've
found that this is my GDAL_DRIVER_PATH environment variable which cause
the problem. I'll check why ...
Thanks
> On Fri, Aug 20, 2010 at 11:39 AM, Fabrice LALLAURET - PSV
> <fabrice.lallauret at external.thalesgroup.com
> <mailto:fabrice.lallauret at external.thalesgroup.com>> wrote:
>     Â I've tried to write some gdal python scripts but in some case
>     I've got unwanted error message. Here is a small example (from
>     gdal tutorial).
>     src_filename  = "src.tif"
>     dst_filename = "dest.tif"
>     # ensure no dest file exists
>     if os.path.exists(dst_filename):
>     Â  Â os.unlink(dst_filename)
>     src_ds = gdal.Open( src_filename  )
>     driver = gdal.GetDriverByName('GTiff')
>     dst_ds = driver.CreateCopy( dst_filename, src_ds, 0, [
>     'TILED=YES', 'COMPRESS=PACKBITS' ] )
>     # Once we're done, close properly the dataset
>     dst_ds = None
>     src_ds = None
>     The src.tif is correctly copied in dest.tif but the console
>     messages are:
>     #>python test.py
>     dest.tif: No such file or directory
>     GTIFF_RAW:dest.tif: No such file or directory
>     What is wrong with this code  or how to eliminate these error
>     messages which aren't useful and may be a bit misleading ?
>     Best Regards
      .--.    Fabrice LALLAURET - PSV Team
     |o_o |   Tel: (33) (01 34) 22 83 47
     |:_/ |   Thales Training&  Simulation
    //   \ \  1, rue du General de Gaulle
   (|     | ) Z.I. les beaux soleils
  /'\_   _/`\ Osny. B.P. 226
  \___)=(___/ 95523 Cergy-Pontoise Cedex
  E-mail:fabrice.lallauret at external.thalesgroup.com
  "Power corrupts. PowerPoint corrupts absolutely."
  My personnal (french) Websites:http://www.xbee.net
  andhttp://www.french-comics-zone.fr.st
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100820/2bf76c7f/attachment-0001.html
