[gdal-dev] RawDataset.h change - might need recompile
Fri Aug 20 09:56:56 EDT 2010
Folks,
I have changed the RawRasterBand class in a way that means all classes
derived from it need to be rebuilt.  It might be that not all the
appropriate dependencies on rawdataset.h are expressed in the makefiles
in which case a clean rebuild will be needed after you next update from svn
trunk.
Best regards,
