[gdal-dev] Create copy without any bands
Tim Keitt
tkeitt at gmail.com
Sat Aug 21 13:24:11 EDT 2010
How about:
/* ShallowCopy() */
GDALDataset *GDALDriver::ShallowCopy( const char * pszFilename,
GDALDataset * poSrcDS,
GDALDataType etype, int nBands,
int bStrict, char ** papszOptions,
GDALProgressFunc pfnProgress )
if( pfnProgress == NULL )
pfnProgress = GDALDummyProgress;
/* Create destination dataset. */
GDALDataset *poDstDS;
int nXSize = poSrcDS->GetRasterXSize();
int nYSize = poSrcDS->GetRasterYSize();
CPLErr eErr;
CPLDebug( "GDAL", "Using default GDALDriver::CreateCopy implementation." );
if( !pfnProgress( 0.0, NULL, pProgressData ) )
CPLError( CE_Failure, CPLE_UserInterrupt, "User terminated" );
return NULL;
poDstDS = Create( pszFilename, nXSize, nYSize, nBands, eType,
papszOptions );
if( poDstDS == NULL )
return NULL;
/* Try setting the projection and geotransform if it seems */
/* suitable. For now we don't try and copy GCPs, though I */
/* suppose we should. Also copy metadata. */
double adfGeoTransform[6];
if( poSrcDS->GetGeoTransform( adfGeoTransform ) == CE_None
&& (adfGeoTransform[0] != 0.0
|| adfGeoTransform[1] != 1.0
|| adfGeoTransform[2] != 0.0
|| adfGeoTransform[3] != 0.0
|| adfGeoTransform[4] != 0.0
|| adfGeoTransform[5] != 1.0) )
poDstDS->SetGeoTransform( adfGeoTransform );
if( poSrcDS->GetProjectionRef() != NULL
&& strlen(poSrcDS->GetProjectionRef()) > 0 )
poDstDS->SetProjection( poSrcDS->GetProjectionRef() );
poDstDS->SetMetadata( poSrcDS->GetMetadata() );
return poDstDS;
On Sat, Aug 21, 2010 at 7:14 PM, Tim Keitt <tkeitt at gmail.com> wrote:
> OK. I found the source. Yes, that is fairly straightforward to copy and modify.
> It seems making a copy without propagating the raster bands would be
> very common operation. Would it make sense to introduce a new function
> to GDAL? ShallowCopy?
> THK
> On Sat, Aug 21, 2010 at 7:05 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>> I noticed DefaultCreateCopy, but appears not to be documented. At
>> least there is no click through link in the class reference. What does
>> it do? How is it modified? In the driver code?
>> THK
>> On Sat, Aug 21, 2010 at 7:00 PM, Chaitanya kumar CH
>> <chaitanya.ch at gmail.com> wrote:
>>> Tim,
>>> You can create it easily by modifying GDALDriver::DefaultCreateCopy()
>>> On Sat, Aug 21, 2010 at 9:51 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>>>> I am writing a utility that takes a raster as input and outputs a
>>>> raster with all attributes the same, except that I only want one
>>>> output band and I want to specify its type independent of the data
>>>> type in the input file. Is there a function that creates a copy of a
>>>> dataset (or creates a virtual dataset), but does not copy any raster
>>>> bands? This would really simplify things as all I would have to do is
>>>> add a band to the output dataset of the desired type.
>>>> THK
>>>> Timothy H. Keitt
>>>> http://www.keittlab.org/
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
>> Timothy H. Keitt
> Timothy H. Keitt
Timothy H. Keitt
