[gdal-dev] Create copy without any bands
Tim Keitt tkeitt at gmail.com
Sat Aug 21 13:32:41 EDT 2010
Oops. This would have to be made a non-member function so a different
driver could be specified.
THK
On Sat, Aug 21, 2010 at 7:24 PM, Tim Keitt <tkeitt at gmail.com> wrote:
> How about:
> /*                         ShallowCopy()                                */
> GDALDataset *GDALDriver::ShallowCopy( const char * pszFilename,
>                                      GDALDataset * poSrcDS,
>                                      GDALDataType etype, int nBands,
>                                      int bStrict, char ** papszOptions,
>                                      GDALProgressFunc pfnProgress )
>    if( pfnProgress == NULL )
>        pfnProgress = GDALDummyProgress;
> /*      Create destination dataset.                                     */
>    GDALDataset  *poDstDS;
>    int          nXSize = poSrcDS->GetRasterXSize();
>    int          nYSize = poSrcDS->GetRasterYSize();
>    CPLErr       eErr;
>    CPLDebug( "GDAL", "Using default GDALDriver::CreateCopy implementation." );
>    if( !pfnProgress( 0.0, NULL, pProgressData ) )
>        CPLError( CE_Failure, CPLE_UserInterrupt, "User terminated" );
>        return NULL;
>    poDstDS = Create( pszFilename, nXSize, nYSize, nBands, eType,
> papszOptions );
>    if( poDstDS == NULL )
>        return NULL;
> /*      Try setting the projection and geotransform if it seems         */
> /*      suitable.  For now we don't try and copy GCPs, though I         */
> /*      suppose we should. Also copy metadata.                          */
>    double      adfGeoTransform[6];
>    if( poSrcDS->GetGeoTransform( adfGeoTransform ) == CE_None
>        && (adfGeoTransform[0] != 0.0
>            || adfGeoTransform[1] != 1.0
>            || adfGeoTransform[2] != 0.0
>            || adfGeoTransform[3] != 0.0
>            || adfGeoTransform[4] != 0.0
>            || adfGeoTransform[5] != 1.0) )
>        poDstDS->SetGeoTransform( adfGeoTransform );
>    if( poSrcDS->GetProjectionRef() != NULL
>        && strlen(poSrcDS->GetProjectionRef()) > 0 )
>        poDstDS->SetProjection( poSrcDS->GetProjectionRef() );
>    poDstDS->SetMetadata( poSrcDS->GetMetadata() );
>    return poDstDS;
> On Sat, Aug 21, 2010 at 7:14 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>> OK. I found the source. Yes, that is fairly straightforward to copy and modify.
>> It seems making a copy without propagating the raster bands would be
>> very common operation. Would it make sense to introduce a new function
>> to GDAL? ShallowCopy?
>> THK
>> On Sat, Aug 21, 2010 at 7:05 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>>> I noticed DefaultCreateCopy, but appears not to be documented. At
>>> least there is no click through link in the class reference. What does
>>> it do? How is it modified? In the driver code?
>>> THK
>>> On Sat, Aug 21, 2010 at 7:00 PM, Chaitanya kumar CH
>>> <chaitanya.ch at gmail.com> wrote:
>>>> Tim,
>>>> You can create it easily by modifying GDALDriver::DefaultCreateCopy()
>>>> On Sat, Aug 21, 2010 at 9:51 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>>>>> I am writing a utility that takes a raster as input and outputs a
>>>>> raster with all attributes the same, except that I only want one
>>>>> output band and I want to specify its type independent of the data
>>>>> type in the input file. Is there a function that creates a copy of a
>>>>> dataset (or creates a virtual dataset), but does not copy any raster
>>>>> bands? This would really simplify things as all I would have to do is
>>>>> add a band to the output dataset of the desired type.
>>>>> THK
>>>>> Timothy H. Keitt
>>>>> http://www.keittlab.org/
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>>> Timothy H. Keitt
>> Timothy H. Keitt
> Timothy H. Keitt
Timothy H. Keitt
