[gdal-dev] Re: projection unsupported?
Hermann Peifer
peifer at gmx.eu
Wed Aug 25 03:09:42 EDT 2010
It looks to me that "Kertau RSO Malaya Meters" is also known as
EPSG:3168. So for the GDAL tools, you could use the EPSG code or this
list of parameters and values:
http://spatialreference.org/ref/epsg/3168/proj4/
Hermann
On 25/08/2010 07:35, Christoph Dohmen wrote:
> Dear list,
> I got some data to deal with which use a projection called
> "Kertau RSO Malaya Meters". From some earlier posts to proj.4
> list I got the information that this is a kind of oblique
> mercator projection. But I can't find anything around gdal
> about how to deal with this projection.
> Do I have to change the SRS before using gdal to deal with
> this data? Or will there be any change inside gdal to support
> this projection? Are there any hints outside I didn' get
> so far?
> Best regards,
> Christoph
