[gdal-dev] I get the following error when running gdalwarp with the -multi switch: ERROR 1: CPLCreateThread() failed in ChunkAndWarpMulti()
Wed Aug 25 09:56:08 EDT 2010
> gdalwarp -multi -tr 1.2 1.2 -rc -s_srs EPSG:26917 -t_srs EPSG:26917
> -co bigtiff=yes  -q "17RMP395060.tif"
> "/tmp/gvAppTemp/gvApp2/m2.tiftemp"
> The -multi switch causes the error but if I take out the -multi switch
> then the command completes.
> When I do the same command on an older linux server with the -multi
> switch then the command does not error off, so it could be that the
> newer server has a later version of gdal that does not like -multi.
> The command will work without the -multi switch which I believe is
> supposed to run the gdalwarp command in multithreaded mode which in
> theory should be faster.
> On a 64 bit version of gdal running on a 64 bit linux does performance
> improve at all if the -multi switch is included and if so how can I
> prevent this error from occurring when using the -multi switch.
John,
It likely means the GDAL was built without threading support.  If you
build yourself, consider using the --with-threads configure option.
Best regards,
