Re: [gdal-dev] libecwj2 ?
Ivan Lucena
ivan.lucena at pmldnet.com
Wed Dec 15 09:19:27 EST 2010
Oyvind,
I tried adding those defines on ecw/makefile.vc and it did worked but I don't know if that is the right thing do to:
- /DLIBECWJ2 /DWIN32 /D_WINDLL -DFRMT_ecw -DNO_X86_MMI
+ /DLIBECWJ2 /DWIN32 /D_WINDLL -DFRMT_ecw -DNO_X86_MMI -DECWSDK_VERSION=41 -DNO_COMPRESS
And, of course, I changed the setting on nmake.opt:
-#ECW_PLUGIN = NO
-#ECWDIR = C:\warmerda\libecwj2-3.3
-#ECWLIB = $(ECWDIR)\Source\NCSBuildQmake\Debug\libecwj2.lib
+ECW_PLUGIN = YES
+ECWDIR = "C:\Program Files\ERDAS\ERDAS ECW JPEG2000 Read SDK"
+ECWLIB = $(ECWDIR)\lib\vc90\win32\NCScnet4.lib \
+ $(ECWDIR)\lib\vc90\win32\NCSEcw4_RO.lib \
+ $(ECWDIR)\lib\vc90\win32\NCSUtil4.lib
That worked on 1.8dev and 1.7.3 as well but I guess we would need an expert opnion on that.
C:\>gdalinfo --format ecw
Format Details:
Short Name: ECW
Long Name: ERMapper Compressed Wavelets
Extension: ecw
Help Topic: frmt_ecw.html
C:\>gdalinfo --version
GDAL 1.7.3, released 2010/11/10
Regards,
Ivan
> -------Original Message-------
> From: Oyvind Idland <oyvind.idland at gmail.com>
> To: Ivan Lucena <ivan.lucena at pmldnet.com>
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] libecwj2 ?
> Sent: Dec 15 '10 07:59
> Thanks Ivan,
> I forgot to mention that I use GDAL 1.7.3.
> It seems to me that the ECW api has changed quite a bit, as 1.7.3
> doesn't compile against it ?
> For instance, I get
> ecwcreatecopy.cpp(896) : error C2039: 'SetKeySize' : is not a
> member of 'NCS::CView'
> In addition, the NCSJPC_EXPORT_ALL macro is being used, and this one does
> no longer
> exist in the new SDK.
> -- Oyvind
> On Tue, Dec 14, 2010 at 3:53 PM, Ivan Lucena <[LINK:
> mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
> yvind,
> There is a new SDK that you can download from Erdas website:
> [LINK: http://www.erdas.com/products/ERDASECWJPEG2000SDK/Downloads.aspx]
> But there are a few changes you would need to do in order to compile the
> GDAL/ECW driver because the path and library names has changed.
> Regards,
> Ivan
> > From: Oyvind Idland <[LINK: mailto:oyvind.idland at gmail.com]
> > To: [LINK: mailto:gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> > Subject: [gdal-dev] libecwj2 ?
> > Sent: Dec 14 '10 07:09
> > Hello,
> > i am compiling GDAL from source, and need the ECW as plugin.
> > The package is mentioned on the site, libecwj2-3.3-2006-09-06.zip, is
> this
> > a package
> > from ERDAS ? I tried to find some info about it on their site, but
> found
> > nothing..
> > I found a couple of other download links, so I can at least get
> started.
> > -- yvind
> > gdal-dev mailing list
> > [LINK: compose.php?to=[LINK: mailto:gdal-dev at lists.osgeo.org]
> gdal-dev at lists.osgeo.org] [LINK: mailto:gdal-dev at lists.osgeo.org]
> > [LINK: [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
