[gdal-dev] libecwj2 ?
Oyvind Idland oyvind.idland at gmail.com
Wed Dec 15 10:21:48 EST 2010
Thanks !
I did allmost exactly the same as you, but didn't include -DNO_COMPRESS.
It compiles fine now. However, seems like it can't load gdal_ECW_JP2ECW.dll
anymore.
I now compile GDAL as a static lib, with ECW as a plugin. Could this result
in GDAL not loading dynamic plugins ?
-- Oyvind
On Wed, Dec 15, 2010 at 3:19 PM, Ivan Lucena <ivan.lucena at pmldnet.com>wrote:
> Oyvind,
> I tried adding those defines on ecw/makefile.vc and it did worked but I
> don't know if that is the right thing do to:
> -        /DLIBECWJ2 /DWIN32 /D_WINDLL -DFRMT_ecw -DNO_X86_MMI
> +        /DLIBECWJ2 /DWIN32 /D_WINDLL -DFRMT_ecw -DNO_X86_MMI
> -DECWSDK_VERSION=41 -DNO_COMPRESS
> And, of course, I changed the setting on nmake.opt:
> -#ECW_PLUGIN = NO
> -#ECWDIR  =     C:\warmerda\libecwj2-3.3
> -#ECWLIB  =     $(ECWDIR)\Source\NCSBuildQmake\Debug\libecwj2.lib
> +ECW_PLUGIN = YES
> +ECWDIR  =     "C:\Program Files\ERDAS\ERDAS ECW JPEG2000 Read SDK"
> +ECWLIB  =     $(ECWDIR)\lib\vc90\win32\NCScnet4.lib \
> +            $(ECWDIR)\lib\vc90\win32\NCSEcw4_RO.lib \
> +            $(ECWDIR)\lib\vc90\win32\NCSUtil4.lib
> That worked on 1.8dev and 1.7.3 as well but I guess we would need an expert
> opnion on that.
> C:\>gdalinfo --format ecw
> Format Details:
>  Short Name: ECW
>  Long Name: ERMapper Compressed Wavelets
>  Extension: ecw
>  Help Topic: frmt_ecw.html
> C:\>gdalinfo --version
> GDAL 1.7.3, released 2010/11/10
> Regards,
> Ivan
> >  -------Original Message-------
> >  From: Oyvind Idland <oyvind.idland at gmail.com>
> >  To: Ivan Lucena <ivan.lucena at pmldnet.com>
> >  Cc: gdal-dev at lists.osgeo.org
> >  Subject: Re: [gdal-dev] libecwj2 ?
> >  Sent: Dec 15 '10 07:59
> >  Thanks Ivan,
> >  I forgot to mention that I use GDAL 1.7.3.
> >  It seems to me that the ECW api has changed quite a bit, as 1.7.3
> >  doesn't compile against it ?
> >  For instance, I get
> >  ecwcreatecopy.cpp(896) : error C2039: 'SetKeySize' : is not a
> >  member of 'NCS::CView'
> >  In addition, the NCSJPC_EXPORT_ALL macro is being used, and this one
> does
> >  no longer
> >  exist in the new SDK.
> >  -- Oyvind
> >  On Tue, Dec 14, 2010 at 3:53 PM, Ivan Lucena <[LINK:
> >  mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
> >  yvind,
> >  There is a new SDK that you can download from Erdas website:
> >  [LINK: http://www.erdas.com/products/ERDASECWJPEG2000SDK/Downloads.aspx
> >  But there are a few changes you would need to do in order to compile the
> >  GDAL/ECW driver because the path and library names has changed.
> >  Regards,
> >  Ivan
> >  >  From: Oyvind Idland <[LINK: mailto:oyvind.idland at gmail.com]
> >  >  To: [LINK: mailto:gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> >  >  Subject: [gdal-dev] libecwj2 ?
> >  >  Sent: Dec 14 '10 07:09
> >  >  Hello,
> >  >  i am compiling GDAL from source, and need the ECW as plugin.
> >  >  The package is mentioned on the site, libecwj2-3.3-2006-09-06.zip, is
> >  this
> >  >  a package
> >  >  from ERDAS ? I tried to find some info about it on their site, but
> >  found
> >  >  nothing..
> >  >  I found a couple of other download links, so I can at least get
> >  started.
> >  >  -- yvind
> >  >  _______________________________________________
> >  >  gdal-dev mailing list
> >  >  [LINK: compose.php?to=[LINK: mailto:gdal-dev at lists.osgeo.org]
> >  gdal-dev at lists.osgeo.org] [LINK: mailto:gdal-dev at lists.osgeo.org]
> >  >  [LINK: [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101215/d3f19511/attachment.html
