[gdal-dev] Black lines across images using GDAL 1.7.2 and above
Even Rouault
even.rouault at mines-paris.org
Wed Dec 15 12:23:26 EST 2010
Le mercredi 15 décembre 2010 12:58:15, Smart, Gary a écrit :
Gary,
I am not aware of such a corruption having been reported. Would you be able to
craft a small self-contained test case (code + data) that you could share and
that exhibits the issue ?
(well the issue you describe reminded me a bit about
http://trac.osgeo.org/gdal/ticket/3458 but this bug was fixed in 1.7.2 and you
didn't mention if your use case involved warping)
> I recently updated our GDAL source to version 1.7.3 from 1.7.1 and
> suddenly we appear to have lots of black lines across any imagery read
> using the GDAL (e.g. NITF files, WMS geotiffs). Wondering if it was a
> 1.7.3 issue, I switched to 1.7.2 which showed exactly the same problem.
> Moving back to 1.7.1 clears it. It looks very much like memory
> corruption and seems to particularly affect the lower half of displayed
> images.
> Has anyone else witnessed such corruption? We need to keep our systems
> up to date with the latest GDAL but cannot move forward with this
> problem in the build.
> We are using GDAL on SLES10.2 Linux.
> Gary
