[gdal-dev] Re: Gdal_translate, WMS source and own certificate
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Dec 21 04:13:48 EST 2010
Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
> We would like to use gdal_translate for reading fromn our WMS service
> which is> secured by our own certificate and thus not automatically
> trusted.  Our developer had a quick look on a gdal source code and
> tried to find how options CURLOPT_SSL_VERIFYPEER (1) and CURLOPT_CAPATH
> (2) are used there.  Numbers are referring to document
> http://curl.haxx.se/docs/sslcerts.html
> The conclusion was that those options are not used and thus it is
> impossible to use dgal_translate with our server.  Is this true, and
> if yes, would it be worth filing a ticket?
We got help for our immediate need by making an own modified build. We opened
also a new ticket about fixing the thing permanently
(http://trac.osgeo.org/gdal/ticket/3882) because our developer wrote me
"Building gdal with curl for Windows is non-trivial".
-Jukka Rahkonen-
