[gdal-dev] Re: Gdal_translate, WMS source and own certificate
Adam Nowacki nowak at xpam.de
Tue Dec 21 04:51:25 EST 2010
Can you test http://trac.osgeo.org/gdal/changeset/21304/trunk ? Add
<UnsafeSSL>true</UnsafeSSL> inside <GDAL_WMS>.
Jukka Rahkonen wrote:
> Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
>> We would like to use gdal_translate for reading fromn our WMS service
>> which is> secured by our own certificate and thus not automatically
>> trusted.  Our developer had a quick look on a gdal source code and
>> tried to find how options CURLOPT_SSL_VERIFYPEER (1) and CURLOPT_CAPATH
>> (2) are used there.  Numbers are referring to document
>> http://curl.haxx.se/docs/sslcerts.html
>> The conclusion was that those options are not used and thus it is
>> impossible to use dgal_translate with our server.  Is this true, and
>> if yes, would it be worth filing a ticket?
> We got help for our immediate need by making an own modified build. We opened
> also a new ticket about fixing the thing permanently
> (http://trac.osgeo.org/gdal/ticket/3882) because our developer wrote me
> "Building gdal with curl for Windows is non-trivial".
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
