[gdal-dev] Re: Gdal_translate, WMS source and own certificate
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Tue Dec 21 08:16:31 EST 2010
Adam Nowacki <nowak <at> xpam.de> writes:
> Can you test http://trac.osgeo.org/gdal/changeset/21304/trunk ? Add
> <UnsafeSSL>true</UnsafeSSL> inside <GDAL_WMS>.
Yes, it works. However, the ticked appeared to be a duplicate for #3510, and the
attached patch is solving the problem as well. You, the developers need to
choose which fix to take. The #3510 fix includes also a way to give username and
password with WMS_XML but on the other hand it would make GDAL WMS driver to
never check the certificates. GDAL WCS skips certificates already and for the
end user it would be nice if WMS and WCS drivers behaves in a similar way, what
ever it is.
-Jukka Rahkonen-
