[gdal-dev] gdal swig python's setup.py not python3 compatible
Vincent Schut
schut at sarvision.nl
Wed Dec 29 08:27:09 EST 2010
Oops, wrong conclusion. Seems more complicated than I thought, as there
are some python checks in configure that use python...
Lets change this into a question:
as I have both python2 and python3, with /usr/bin/python linking to
python3 (so python3 is the default), and gdal's python extension seems
to be not python3 compatible (at least the build/install method), what
would be the prefered way to have gdal's configure/make/make install use
python2 for everything? E.g. use /usr/bin/python2 as executable, and the
python2 site-packages dir for installing.
As lots of my own scripts and other extensions I use are still not
really python3-ready, I don't mind using python2 myself, but I'd like to
keep the system default to python3 because I don't want to mess to much
with my system's defaults (I tend to forget stuff I change manually, etc.)
Tia,
Vincent.
On 12/29/2010 02:19 PM, Vincent Schut wrote:
> Hi,
> some time ago, Arch linux made the rather bold decision to have python3
> as system python default, of course with a /usr/bin/python2 alternative
> sitting next to it. However, as the /usr/bin/python link is pointing to
> /usr/bin/python3, gdal's swig python module's setup.py is being called
> with python3, and appears to be not python3 compatible:
> checking for python bindings... checking for python... python
> checking for location of Python Makefiles... File "<string>", line 3
> print sys.prefix
> SyntaxError: invalid syntax
> print sys.prefix
> print sys.version[:3]
> found
> checking where to install Python modules... /lib/python/site-packages
> enabled
> checking for python setuptools... File "<string>", line 3
> print 1
> not found
> configure: checking whether we should include rasdaman support...
> rasdaman support not requested.
> configure: creating ./config.status
> config.status: creating GDALmake.opt
> Imho the easiest way to fix this would be to have a '#!/usr/bin/python2'
> as first line in setup.py; I suppose every distro has also a
> /usr/bin/python2 executable/link, even if there is not yet a python3 one.
> Regards,
> Vincent.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
