[gdal-dev] ODBC as OGR data source?
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Feb 5 00:37:32 EST 2010
Gregor,
The segfault occurred at
http://trac.osgeo.org/gdal/browser/branches/1.7/gdal/port/cpl_odbc.cpp#L796during
a call to memcpy.
You mentioned that there was an attempt by CPLMalloc to allocate 4294967297
bytes of memory. There may be an integer overflow. There were similar
problems elsewhere in GDAL.
If you can provide a sample dataset please file a bug report at
http://trac.osgeo.org/gdal/newticket mentioning your database and driver
setup.
---------- Forwarded message ----------
Date: Fri, Feb 5, 2010 at 10:29 AM
Subject: Re: [gdal-dev] ODBC as OGR data source?
To: Chaitanya kumar CH <chaitanya.ch at gmail.com>
Okay, here you go...
http://pastebin.com/m18fce732
HostGIS, Open Source solutions for the global GIS community
Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
Network+ Server+ A+ Security+ Linux+
PHP PostgreSQL MySQL DHTML/JavaScript/AJAX
"No one cares if you can back up — only if you can recover."
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100205/90d7b14d/attachment-0001.html
