[gdal-dev] Important - GDAL 1.7.0 - Imagine/HFA Driver Produces
Corrupt Files
Tamas Szekeres
szekerest at gmail.com
Fri Feb 5 15:01:36 EST 2010
+1 for the new release.
Best regards,
Tamas
2010/2/5 Frank Warmerdam <warmerdam at pobox.com>
> Folks,
> Ivan has discovered that GDAL 1.7.0 is producing HFA files that are
> corrupt - that is they are only readable with GDAL. Imagine and older
> versions of ArcGIS fail to read them. The problem is described in:
> http://trac.osgeo.org/gdal/ticket/3382
> I consider this problem very serious, and the longer that GDAL 1.7.0
> is in use the more of these corrupt Imagine files will be produced and
> cause problems for the world. For that reason, I would like to press
> ahead to produce a GDAL 1.7.1 release soon, and to mark GDAL 1.7.0
> deprecated
> due to this serious bug. Does anyone feel this is overkill?
> Are there any other high priority fixes folks would like to see in a GDAL
> 1.7.1
> release? I am thinking of preparing an RC on Monday if there is no
> objection.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100205/1ab50bfa/attachment.html
