[gdal-dev] Cannot set transparent color for GeoTIFFs
Ralf Wagner
rpw at globema.pl
Mon Feb 8 17:08:52 EST 2010
Thanks a lot!!!
It was crucial - to expand color table to RGB! After that everything
works perfect.
Once again: big thank you!
Ralf Wagner
Chaitanya kumar CH pisze:
> From what Ed said, editing the color table is useless. Try to expand
> the tiff to rgb and proceed from there. At least the error message
> should change. ;-)
> On Mon, Feb 8, 2010 at 8:52 PM, Grissom, Edward (Ed)
> <ed.grissom at intergraph.com <mailto:ed.grissom at intergraph.com>> wrote:
> Are you aware that the TIFF (and GeoTIFF) spec does not allow you
> to set
> a transparent color ?
> The TIFF spec allows a transparency bit-mask or an alpha channel
> -- each
> of which covers the entire image, but does not allow a specific color
> value to be used as transparent.
> I believe that the spec also forbids a alpha channel on the color
> table
> itself. It may allow one on a color indexed image, but it may be
> that
> GDAL has not implemented support for that yet.
> ed grissom
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9848167848
> 17.241582N 80.142635E
Ralf Wagner
Globema Sp. z o.o., ul. Rostafińskich 4, 02-593 Warszawa, Poland
tel. (+48) 22 848 73 13, fax (+48) 22 848 68 83
www.globema.com.pl <http://www.globema.com.pl>
"Treść tej wiadomości może zawierać prawnie chronione informacje poufne.
Jeśli otrzymaliście ją Państwo przez pomyłkę, prosimy o niezwłoczne
powiadomienie o tym nadawcy oraz jej usunięcie z Państwa komputera, bez
wykonywania, dystrybuowania lub zatrzymywania jakiejkolwiek jej kopii.
This message may contain confidential information protected by law. If
you have received this message by mistake, please immediately inform the
sender of the mistake and delete this message from your system without
making, distributing or retaining any copies of it."
