[gdal-dev] Oracle OCI connection in Python OGR
Eric Wolf
ebwolf at gmail.com
Fri Feb 12 13:02:52 EST 2010
Thanks for the replies. Sorry I didn't give more details on the environment.
I am running on Windows, at the command line, both ogr2ogr and the python
script.
Created an environment variable for ORACLE_SID=ORCL
I double-checked my OCI string by using sqlplus to connect:
sqlplus scott/tiger at orcl
This works fine. I changed the script to use that in the call to ogr.Open().
No luck.
I imported gdal and sprinkled print 'Error:', gdal.GetLastErrorMsg() in my
exception handlers. I got:
Unable to open Oracle connection None
Error:
Still no dice. If I take the same script and modify the GetDriverByName and
Open to use a shapefile, it works perfectly.
-Eric
Eric B. Wolf New! 720-334-7734
USGS Geographer
Center of Excellence in GIScience
PhD Student
CU-Boulder - Geography
GPG Public Key: http://www.h4h.net/ebwolf.public.key.txt
On Fri, Feb 12, 2010 at 6:56 AM, Abhay <abhay.menon at gmail.com> wrote:
> On Fri, Feb 12, 2010 at 2:48 PM, Eric Wolf <ebwolf at gmail.com> wrote:
>> I'm using GDAL/OGR 1.6.1 with ActivePython 2.6.4-10 and
>> cx_Oracle-5.0.3-11g. I am trying to connect to an Oracle 11g instance.
>> This works:
>> ogr2ogr -f "KML" emp.kml OCI:scott/tiger "EMP"
>> What am I doing wrong. This fails, ds is None:
>> from osgeo import ogr
>> try:
>> d = ogr.GetDriverByName('OCI')
>> except:
>> print "Unable to GetDriverByName"
>> quit()
>> ds = None
>> try:
>> ds = ogr.Open('OCI:scott/tiger')
>> except:
>> print "Unable to open OCI connection"
>> quit()
>> if ds is None:
>> print "Unable to open Oracle connection", ds
>> quit()
>> lyr = ds.GetLayerByName('EMP')
>> number = lyr.GetFeatureCount()
>> print "Features: " + str(number)
>> USGS Geographer
>> PhD Student
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Hi Eric,
> Form your mail it not clear what is cause of the problem.
> There 2 scenario here
> 1) you are on a remote machine form where your trying to connect oracle
> server machine:
> a) Have you installed any Oracle Client in your system. Considering that
> you are using the complete oracle client installation you can use the
> following :
> OCI:scott/tiger@<Tnsname entry for eg. ORCL>
> b) if you are trying out with Instant client for 11g you should try either
> of the following
> OCI:scott/tiger@//localhost/<your ORACLE SERVICE IDENTIFIER for eg ORCL>.
> 2) you are on the oracle server machine where
> you must set the oracle SID. like the following
> on windows
> SET ORACLE_SID=ORCL
> or
> on *nix
> export ORACLE_SID=ORCL
> then try your implementation or use methods stated in 1)
> Rgds.
> Abhay.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100212/b0076299/attachment.html
