[gdal-dev] Re: corrupt block on AIG dataset
Even Rouault
even.rouault at mines-paris.org
Sun Feb 14 17:43:31 EST 2010
Omer,
I've downloaded the dataset and run gdalinfo -checksum on it successfully (I'm
using gdal-trunk - equivalent to 1.7 as far as AIG is concerned on 64bit
Linux)
Now I'm running your script (with a slight modification to use the dataset as
mask too), and until here (takes quite a long time to run!), I see no
problem.
Not sure why you get errors...
Le Sunday 14 February 2010 22:41:40 ozak, vous avez écrit :
> Hi Even and community,
> here's the link to the dataset that causes the error:
> http://www.econ.brown.edu/students/Omer_Ozak_Munoz/Datasets/afgdist.zip
> Data
> I was using the following code which used another dataset to create a mask,
> but that's not the issue, so it could be simply deleted. I really
> appreciate your help.
> Best,
> Omer
> import os, sys, time
> try:
> from osgeo import gdal, gdalconst
> from osgeo.gdalconst import *
> import numpy
> use_numeric = False
> except:
> from gdalconst import *
> import Numeric
> use_numeric = True
> # start timing
> startTime=time.time()
> pais = 'afg'
> file= pais+'.txt'
> file = open(file,'w')
> # prepare gdal for importing ARCGIS binary grid
> #gdal.AllRegister()
> driver = gdal.GetDriverByName('AIG')
> driver.Register()
> if use_numeric:
> # set the directory
> dire='/direct/'
> else:
> dire='/Volumes/direct/'
> # the file to open
> fn = dire+'timehours'
> mask = gdal.Open(fn, GA_ReadOnly)
> if mask is None:
> print('Could not open' + fn)
> sys.exit(1)
> else:
> #determine info of grid
> mcols = mask.RasterXSize
> mrows = mask.RasterYSize
> mbands = mask.RasterCount
> mgeotransform = mask.GetGeoTransform()
> moriginX = mgeotransform[0]
> moriginY = mgeotransform[3]
> mpixelWidth = mgeotransform[1]
> mpixelHeight = mgeotransform[5]
> mband = mask.GetRasterBand(1)
> # set the directory
> if use_numeric:
> os.chdir('/direct')
> else:
> os.chdir('/Volumes/direct')
> # the file to open
> fn = pais+'dist'
> ds = gdal.Open(fn, GA_ReadOnly)
> if ds is None:
> print('Could not open ' + fn)
> sys.exit(1)
> else:
> cols = ds.RasterXSize
> rows = ds.RasterYSize
> bands = ds.RasterCount
> geotransform = ds.GetGeoTransform()
> originX = geotransform[0]
> originY = geotransform[3]
> pixelWidth = geotransform[1]
> pixelHeight = geotransform[5]
> band = ds.GetRasterBand(1)
> # read the whole data
> #data = band.ReadAsArray(0, 0, cols, rows)
> # read only a couple of lines in (x,y)
> x=-2684213
> y=6146882
> #x=1000000
> #y=1000000
> suma=0
> count=0
> maxi=0
> xOffset = int((x-originX) / pixelWidth)
> yOffset = int((y-originY) / pixelHeight)
> y = -3883447
> yend = int((y-originY) / pixelHeight)
> xBsize = 100
> yBsize = 100
> #print 'mrows='+str(mrows)+' mcol='+str(mcols)
> #print 'rows='+str(rows)+' col='+str(cols)
> #print 'xoffset=' + str(xOffset) +', yoffset=' + str(yOffset)
> for j in range(xOffset,cols,xBsize):
> if j + xBsize <= cols:
> ncols=xBsize
> else:
> ncols=cols-j
> for i in range (yOffset,yend,yBsize):
> if i+yBsize<=yend:
> nrows=yBsize
> else:
> nrows=yend-i
> if use_numeric:
> data = band.ReadAsArray(j, i, ncols ,
> nrows).astype(Numeric.Float)
> mdata = mband.ReadAsArray(j, i, ncols , nrows)
> mdata = Numeric.greater(data,0)
> data = data * mdata
> count = Numeric.sum(Numeric.sum(mdata))+count
> suma = Numeric.sum(Numeric.sum(data))+suma
> maxi = max(max(max(data)), maxi)
> else:
> nrows).astype(numpy.float32)
> mdata = numpy.greater(mdata,0)
> data = data * mdata
> count = numpy.sum(numpy.sum(mdata))+count
> suma = numpy.sum(numpy.sum(data))+suma
> maxi=numpy.maximum(numpy.max(data),maxi)
> #print 'i=' +str(i)+' j='+str(j)+' count=' +str(count)
> print(' media=' + str(suma / count)+' max=' +str(maxi)+'
> suma='+str(suma)+' count='+str(count))
> file.write('code,mean,max,sum \n')
> file.write(pais+ str(suma/count)+','+str(maxi)+','+str(suma)+' \n')
> #print 'bands=' + str(bands) + ', originX=' + str(originX) + ',
> originY=' + str(originY)
> print('xoffset=' + str(xOffset) +', yoffset=' + str(yOffset))
> endTime=time.time()
> print('It took ' + str(startTime-endTime) + ' seconds')
> file.close()
