[gdal-dev] Re: corrupt block on AIG dataset
ozak
ozak at BROWN.EDU
Sun Feb 14 19:09:23 EST 2010
Hi Even,
that's exactly my problem...sometimes it works. Others it fails without any
reason.
I thought it had to do with the speed of connection between the linux server
and the windows computer that holds the data, which was causing the problem,
but I tried running it directly with FWTools on the windows computer, but it
still generated the same problem.
View this message in context: http://n2.nabble.com/Re-corrupt-block-on-AIG-dataset-tp4568372p4572259.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
