[gdal-dev] HDF5 information regarding Coordinate System and GCP
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Feb 17 06:23:19 EST 2010
Pedro,
You need to specify the individual subdataset of the hdf5 file to retrieve
the metadata. This page, http://www.gdal.org/frmt_hdf5.html , shows a way to
do it in gdalinfo. GRASS should be in similar lines.
On Wed, Feb 17, 2010 at 4:25 PM, Pedro Roma <pedroroma1982 at gmail.com> wrote:
> Greetings
> I'm a GRASS user and I'm dealing with some difficulties with HDF5
> import/translate. I'm using gdal_translate to import HDF5 files to GRASS but
> I need to use GCP's information and coordinate system. My question is, using
> GDAL tools how can I import/use GCP and coordinate systems that are
> associated with each Subset and that I can "see" using gldalinfo.
> Thank you
> Best regards
> pedro
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100217/526db30d/attachment.html
