[gdal-dev] HDF5 information regarding Coordinate System and GCP
Pedro Roma
pedroroma1982 at gmail.com
Wed Feb 17 07:00:15 EST 2010
Hi
I have specified individual subdataset and I have run gdalinfo but it only
writes in the terminal window it doesn't store in a specific file to be
read.
As it says in that link: This driver is intended only for importing remote
sensing and geospatial datasets in form of raster image. There is nothing
mentioning georrectify using GCP points included in HDF5 file.
On Wed, Feb 17, 2010 at 11:23 AM, Chaitanya kumar CH <chaitanya.ch at gmail.com
> wrote:
> Pedro,
> You need to specify the individual subdataset of the hdf5 file to retrieve
> the metadata. This page, http://www.gdal.org/frmt_hdf5.html , shows a way
> to do it in gdalinfo. GRASS should be in similar lines.
> On Wed, Feb 17, 2010 at 4:25 PM, Pedro Roma <pedroroma1982 at gmail.com>wrote:
>> Greetings
>> I'm a GRASS user and I'm dealing with some difficulties with HDF5
>> import/translate. I'm using gdal_translate to import HDF5 files to GRASS but
>> I need to use GCP's information and coordinate system. My question is, using
>> GDAL tools how can I import/use GCP and coordinate systems that are
>> associated with each Subset and that I can "see" using gldalinfo.
>> Thank you
>> Best regards
>> pedro
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9848167848
> 17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100217/492781ad/attachment.html
