[gdal-dev] Re: installing GDAL for pythonwin: can import and use
gdal, but not gdal_translate
anotherObject
ytrapaet at hotmail.com
Thu Feb 18 02:10:55 EST 2010
Chaitanya - thank you! i am not used to much GIS programming outside of the
pythonwin context. Im glad its not a setup problem.
I'm not sure i need to make some more changes to my environment that are not
mentioned in that pdf article describing the setup GDAL; every time i try
any sort of commands that are mentioned in the GDAL utilities page from the
Start -> Run -> cmd, once i press ok, i see the black DOS screen for a split
second, then it disappears, so i cant see the displayed information that
something like gdalinfo gives. sorry for being such a newbie.
ive also glanced at a few resources that talk about how to do batch
processing with GDAL utilities - what is the actual language that is being
used in this command window (for batch, or any type of commands)?
View this message in context: http://n2.nabble.com/installing-GDAL-for-pythonwin-can-import-and-use-gdal-but-not-gdal-translate-tp4590165p4590386.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
