[gdal-dev] Warp a file from two separate Lat and Long
Andrew Clegg
ancl at pml.ac.uk
Thu Feb 18 12:37:14 EST 2010
Hi Luisa,
I've tried something similar in the past with satellite data. I had 3
files, containing latitude, longitude and value stored as floats. I had
some very minor success with the following solution (I got out an image
but it seemed to drop to a very low resolution). I'm posting it more in
the hope that someone else may be able to spot what I did wrong, because
I would still really like to be able to do this.
My approach was to create a virtual dataset for each file:
sst.vrt (the values):
<VRTDataset rasterXSize="1296" rasterYSize="2030">
<Metadata domain="GEOLOCATION">
<MDI key="X_DATASET">lon.vrt</MDI>
<MDI key="X_BAND">1</MDI>
<MDI key="Y_DATASET">lat.vrt</MDI>
<MDI key="Y_BAND">1</MDI>
<MDI key="PIXEL_OFFSET">0</MDI>
<MDI key="LINE_OFFSET">0</MDI>
<MDI key="PIXEL_STEP">1</MDI>
<MDI key="LINE_STEP">1</MDI>
</Metadata>
<VRTRasterBand dataType="Float32" band="1" subClass="VRTRawRasterBand">
<SourceFilename relativetoVRT="1">sst.img</SourceFilename>
<ImageOffset>0</ImageOffset>
<PixelOffset>4</PixelOffset>
<LineOffset>5184</LineOffset>
<ByteOrder>LSB</ByteOrder>
</VRTRasterBand>
</VRTDataset>
lon.vrt (longitude): (latitude is basically the same)
<SourceFilename relativetoVRT="1">lon.img</SourceFilename>
</VRTRasterBand>
</VRTDataset>
I then tried to run gdalwarp on sst.vrt, trying either '-geoloc' or '-to
METHOD=GEOLOC_ARRAY'.
Regards,
Andrew Clegg
Plymouth Marine Laboratory
Luisa Peña wrote:
> Greetings
> I've used GDAL a few times but this is the first time that I'm lost on
> what I can do with GDAL to solve my problem. I have 3 separate files,
> one with my data, other with Lattitude and another with Longitude.
> They have the same size and, as an example, it means that Pixel (1,1)
> of data is located in latitude retrieved from Pixel (1,1) from
> latitude and longitude (pixel (1,1) from longitude). All of them are
> in WGS84 but without GCP's points.
> I need to create a georreferenced/rectified Geotiff with this data
> and, to do that, I need lat and Long. How can I do this?
> Thanks
> Best regards,
> Luisa Peña
> S.Paulo, Brazil
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Registered Office:
Prospect Place
The Hoe
Plymouth PL1 3DH
Website: www.pml.ac.uk
Registered Charity No. 1091222
PML is a company limited by guarantee
registered in England & Wales
company number 4178503
PML is a member of the Plymouth Marine Sciences Partnership
Website: www.pmsp.org.uk
This e-mail, its content and any file attachments are confidential.
If you have received this e-mail in error please do not copy, disclose it to any third party or use the contents or attachments in any way. Please notify the sender by replying to this e-mail or e-mail forinfo at pml.ac.uk and then delete the email without making any copies or using it in any other way.
The content of this message may contain personal views which are not the views of Plymouth Marine Laboratory unless specifically stated.
You are reminded that e-mail communications are not secure and may contain viruses. Plymouth Marine Laboratory accepts no liability for any loss or damage which may be caused by viruses.
