[gdal-dev] Projection issue with a netcdf file
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 18 15:02:14 EST 2010
Kyle Shannon wrote:
> Frank,
> I have been working on this issue for some time and the driver has a
> quirky way of handling spatial reference parameters. If a tag is not
> present, the netCDFDataset::FetchCopyParms() function returns a default
> value. Currently, those default values are all specified as 0.0.
> Because of this, there is no error and my projection is set with several
> 0.0 values. I have fixed the standard parallel issue on my local
> machine and it now supports CF-1 tags(standard_parallel) as well as gdal
> tags (standard_parallel_1 and standard_parallel_2). I would like to
> continue to update the driver for other tags that have been added to CF,
> but still support gdal tags as well, but I am not sure if my programming
> methods will be suitable. I would hate to do a bunch of work and not be
> able to incorporate it. Any thoughts on how to go about this?
Kyle,
I would welcome you contributing improvements in this area. I will attempt
to apply the patches even though I am not so familiar with the details of
the driver.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
