[Gdal-dev] Problem with gdal_translate
NopMap ekkehart at gmx.de
Mon Jan 11 15:29:56 EST 2010
Hi!
Frank Warmerdam wrote:
> You need to specify the corners in the coordinate system of the
> image.  So the values should be the meter based projected coordinates
> like 1102062,6818226.
Is this also true for -projwin? From the documentation I got the impression
that -srcwin requires meters while -projwin accepted the coordinates in
lat/lon??
bye
          Nop
View this message in context: http://n2.nabble.com/Problem-with-gdal-translate-tp4287843p4287956.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
