[Gdal-dev] Problem with gdal_translate
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 11 15:33:57 EST 2010
NopMap wrote:
> Hi!
> Frank Warmerdam wrote:
>> You need to specify the corners in the coordinate system of the
>> image. So the values should be the meter based projected coordinates
>> like 1102062,6818226.
> Is this also true for -projwin? From the documentation I got the impression
> that -srcwin requires meters while -projwin accepted the coordinates in
> lat/lon??
Nop,
-srcwin takes the locations in pixel/line coordinate system. -projwin
takes it in the coordinate system of the image, which might be projected
or geographic depending on the image. But from the gdalinfo report I can
see your image is projected.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
