[Gdal-dev] Problem with gdal_translate
NopMap ekkehart at gmx.de
Mon Jan 11 17:09:03 EST 2010
Hi!
Frank Warmerdam wrote:
> NopMap wrote:
>> Is this also true for -projwin? From the documentation I got the
>> impression
>> that -srcwin requires meters while -projwin accepted the coordinates in
>> lat/lon??
> -srcwin takes the locations in pixel/line coordinate system.  -projwin
> takes it in the coordinate system of the image, which might be projected
> or geographic depending on the image.  But from the gdalinfo report I can
> see your image is projected.
Ah, I understand. Now it is working. Thank you.
          Nop
View this message in context: http://n2.nabble.com/Problem-with-gdal-translate-tp4287843p4288482.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
