[gdal-dev] gdalwarp query
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 19 11:58:51 EST 2010
SriRam.PrasadBhasker at rmsi.com wrote:
> Hi.
> GDAL Warp generates a Resampled Output Image along with a TFW for a
> provided set of GCP's
> My question is .. is there any Parameter by which we keep the raw image
> untouched & generate only the TFW.
> By Adjusting the TFW parameters we can position the raw image @
> geopositioned Location..
> Any guidance would help immensely.
Bhasker,
In the C API there is a function GDALGCPsToGeoTransform() which can be used
to compute an approximate geotransform for a set of GCPs. This could then
be written to a world file.
There is no mechanism I am aware of in the swig API or with user tools to
do this.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
