Re: [gdal-dev] Oracle GeoRaster loading problem
Ivan Lucena ivan.lucena at pmldnet.com
Thu Jul 8 12:11:49 EDT 2010
See http://trac.osgeo.org/gdal/ticket/3673
>  -------Original Message-------
>  From: Pasta Bolognese <pasta.bolognese at gmail.com>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Oracle GeoRaster loading problem
>  Sent: Jul 08 '10 11:06
>  Hi All,
>  after loading a raster, I've did the traditional
>  SELECT id, sdo_geor.validategeoraster(georaster) isvalid from arcviewgrid;
>  and I've got: 1 13454 ([LINK: http://ora-13454.ora-code.com/]
>  http://ora-13454.ora-code.com/)
>  therefore I've run
>  SELECT sdo_geor.schemaValidate(georaster) from arcviewgrid;
>  ORA-31154: invalid XML document
>  ORA-19202: Error occurred in XML processing
>  LSX-00204: extra data at end of complex element
>  ORA-06512: at "SYS.XMLTYPE", line 354
>  ORA-06512: at "MDSYS.SDO_GEOR", line 3263
>  31154. 00000 -  "invalid XML document"
>  *Cause:    The XML document is invalid with respect to its XML Schema.
>  *Action:   Fix the errors identified and try again.
>  that means that GDAL GeoRaster is generating a wrong metadata XML..
>  Any Ideas ?
>  thanks !
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
