[gdal-dev] Oracle GeoRaster loading problem
Pasta Bolognese
pasta.bolognese at gmail.com
Thu Jul 8 18:35:14 EDT 2010
ooo... is there any workaround ?
Even any query to run in order to fix the XML... ?
On Thu, Jul 8, 2010 at 5:11 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> See http://trac.osgeo.org/gdal/ticket/3673
> > -------Original Message-------
> > From: Pasta Bolognese <pasta.bolognese at gmail.com>
> > To: gdal-dev at lists.osgeo.org
> > Subject: [gdal-dev] Oracle GeoRaster loading problem
> > Sent: Jul 08 '10 11:06
> > Hi All,
> > after loading a raster, I've did the traditional
> > SELECT id, sdo_geor.validategeoraster(georaster) isvalid from
> arcviewgrid;
> > and I've got: 1 13454 ([LINK: http://ora-13454.ora-code.com/]
> > http://ora-13454.ora-code.com/)
> > therefore I've run
> > SELECT sdo_geor.schemaValidate(georaster) from arcviewgrid;
> > ORA-31154: invalid XML document
> > ORA-19202: Error occurred in XML processing
> > LSX-00204: extra data at end of complex element
> > ORA-06512: at "SYS.XMLTYPE", line 354
> > ORA-06512: at "MDSYS.SDO_GEOR", line 3263
> > 31154. 00000 - "invalid XML document"
> > *Cause: The XML document is invalid with respect to its XML Schema.
> > *Action: Fix the errors identified and try again.
> > that means that GDAL GeoRaster is generating a wrong metadata XML..
> > Any Ideas ?
> > thanks !
> > gdal-dev mailing list
> > [LINK: compose.php?to=gdal-dev at lists.osgeo.org]
> > [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100708/0920b1e8/attachment.html
