[gdal-dev] JPEG2K ECW and Erdas ER Viewer
Marc Jacquin marc.jacquin at magellium.fr
Tue Jul 13 10:38:12 EDT 2010
Sorry guys, forget about it! You have to zoom once in ER Viewer or use the
measure tool once to display coordinate information. Moving the cursor over
the window or panning do not display coordinates in the bottom right area
when the file is opened.
Marc
-----Message d'origine-----
De : gdal-dev-bounces at lists.osgeo.org
[mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Jean-Claude REPETTO
Envoyé : mardi 13 juillet 2010 16:25
À : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] JPEG2K ECW and Erdas ER Viewer
Le 13/07/2010 14:48, Marc Jacquin a écrit :
> Hi all,
> We are generating JP2 ECW images with GDAL CSharp binding. OpenEV
> displays them correctly and the gdalinfo reports correct corner
> coordinates. However, Erdas ER Viewer version 10 (formerly ERMapper
> Viewer) cannot find coordinate information. Any idea?
Hi Marc,
You can check the datum, projection and coordinates data of your ECW
file with "ECW Header Editor", available at
<http://www.erdas.com/Products/ERDASProductInformation/tabid/84/currentid/25
08/default.aspx>
Jean-Claude
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
