[gdal-dev] GDAL2Tiles
Gajera Tejas
tejas.gajera at gmail.com
Wed Jul 14 14:00:57 EDT 2010
Guillaume,
I have stated tiles generation process two days ago and counter of
GDAL2Tiles is still on 0 (not even 0...). Do you have any idea how to
improve the process speed?
Regards,
Tejas Gajera
On Wed, Jul 14, 2010 at 12:59 PM, Guillaume Sueur
<no-reply at neogeo-online.net> wrote:
> Hi,
> That can last a bit. It depends on your geo extent and how many base tiles
> will be generated. Gdal2tiles outputs a 10...20... counter, which should
> help you calculate the global time.
> Regards
> Guillaume
> Le 14/07/2010 16:33, Tejas Gajera a écrit :
>> Hi,
>> I have a Tiff image of around 30GB, and I want to create tiles using
>> GDAL2Tiles command line utility. If anyone have used GDAL2Tiles command
>> utility, please let me know how long it takes to generate all tiles?
>> I have started tilling process two days ago and its still running (under
>> process). I have no idea how long it going to take.
>> Please throw anything you know about GDAL2Tiles.
>> Thanks in advance.
>> Best,
>> Tejas Gajera
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
