[gdal-dev] GDAL2Tiles
Guillaume Sueur no-reply at neogeo-online.net
Wed Jul 14 17:07:59 EDT 2010
something is probably going wrong.
can you have a look at the ram and cpu usage ? The system may be swapping.
Le 14/07/2010 20:00, Gajera Tejas a écrit :
> Guillaume,
> I have stated tiles generation process two days ago and counter of
> GDAL2Tiles is still on 0 (not even 0...). Do you have any idea how to
> improve the process speed?
> Regards,
> Tejas Gajera
> On Wed, Jul 14, 2010 at 12:59 PM, Guillaume Sueur
> <no-reply at neogeo-online.net>  wrote:
>> Hi,
>> That can last a bit. It depends on your geo extent and how many base tiles
>> will be generated. Gdal2tiles outputs a 10...20... counter, which should
>> help you calculate the global time.
>> Regards
>> Guillaume
>> Le 14/07/2010 16:33, Tejas Gajera a écrit :
>>> Hi,
>>> I have a Tiff image of around 30GB, and I want to create tiles using
>>> GDAL2Tiles command line utility. If anyone have used GDAL2Tiles command
>>> utility, please let me know how long it takes to generate all tiles?
>>> I have started tilling process two days ago and its still running (under
>>> process). I have no idea how long it going to take.
>>> Please throw anything you know about GDAL2Tiles.
>>> Thanks in advance.
>>> Best,
>>> Tejas Gajera
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
