[gdal-dev] Re: Swig-problem, possibly
Tomas R monshi at home.se
Wed Jul 21 07:36:34 EDT 2010
  Yes, you are correct...
An investigation led me to the same conclusion. I guess most of the
users of previous version of my plugin, which was compiled with VSE2008,
had the correct libraries installed.
Same problem was seen even with that version but not so often as now.
Thanks, always nice to learn something new.
Yours
Tomas
Jürgen E. Fischer skrev 2010-07-21 13:05:
> Hi Tomas,
> On Wed, 21. Jul 2010 at 12:50:31 +0200, Tomas R wrote:
>> is that really as it should be? Should really the result depend on files
>> from the environment it was compiled in? Must I go back to VSE2008 and
>> recompile Gdal to make it work on all machines or is there a setting
>> somewhere...
> I think so.  At least it has been that way since VS2005.
> So VSE2008 should have the same problem, although it's more likely to find the
> necessary dependencies - ie. a preinstalled redist package - on the target
> machine already.   You just need [1], I suppose.
> Jürgen
> [1] http://www.microsoft.com/downloads/details.aspx?FamilyID=a7b7a05e-6de6-4d3a-a423-37bf0912db84&displaylang=en
