[gdal-dev] Clearing OGR Attribute Filter on ESRI Personal Geodatabase
Fri Jul 30 10:10:27 EDT 2010
Joel Odom wrote:
> What's the process by which I can submit that change, or request to have
> someone with commit access add it?  Thanks.
Joel,
If you got to the url I reference below there are brief instructions
in the first paragraph on how to file a ticket.  Basically you get an
OSGeo Userid at:
   https://www.osgeo.org/cgi-bin/ldap_create_user.py
And then you login to the Trac site with it.  Once logged in you can
create a ticket at:
   http://trac.osgeo.org/gdal/newticket
A GDAL committer will act on the ticket and incorporate a change into the
code base.
Best regards,
> On Fri, Jul 30, 2010 at 9:54 AM, Frank Warmerdam <warmerdam at pobox.com
> <mailto:warmerdam at pobox.com>> wrote:
>     Could you file a ticket on this issue at http://trac.osgeo.org/gdal?
