[gdal-dev] Clearing OGR Attribute Filter on ESRI Personal Geodatabase
Joel Odom joelodom at gmail.com
Fri Jul 30 10:22:05 EDT 2010
Thanks, Frank.  See
http://trac.osgeo.org/gdal/ticket/3706
<http://trac.osgeo.org/gdal/ticket/3706>
On Fri, Jul 30, 2010 at 10:10 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Joel Odom wrote:
>> What's the process by which I can submit that change, or request to have
>> someone with commit access add it?  Thanks.
> Joel,
> If you got to the url I reference below there are brief instructions
> in the first paragraph on how to file a ticket.  Basically you get an
> OSGeo Userid at:
>  https://www.osgeo.org/cgi-bin/ldap_create_user.py
> And then you login to the Trac site with it.  Once logged in you can
> create a ticket at:
>  http://trac.osgeo.org/gdal/newticket
> A GDAL committer will act on the ticket and incorporate a change into the
> code base.
> Best regards,
>  On Fri, Jul 30, 2010 at 9:54 AM, Frank Warmerdam <warmerdam at pobox.com<mailto:
>> warmerdam at pobox.com>> wrote:
>>    Could you file a ticket on this issue at http://trac.osgeo.org/gdal?
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
http://www.operationliberate.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100730/1871257c/attachment.html
