[OSSIM] [gdal-dev] Pretty Much Off Topic: Development IDEs
Massimo Di Stefano
massimodisasha at gmail.com
Wed Jun 2 16:09:06 EDT 2010
I'm using :
Spyder [1]
as matlab replacement, it's a relative young project,
has a *lot* of nice feature (see its web page)
like embedded matplotlib, data storage in table (with ) graph sometime i start it from the grass shell
to work directly inside a "grass environment"
and as a simple and lightweight editor i use
Editra [2]
it can run python script, nvavigate trough class, autocompletition etc..
it is really fast when i need to open large files.
while i had bad performance using Eric when i try to load large files.
[1] : http://packages.python.org/spyder/
[2] : http://editra.org/
Il giorno 02/giu/2010, alle ore 17.58, Alex Mandel ha scritto:
> Python - ERIC or SPE(Stani's Python Editor)
> C++ - Code::Blocks looks very good (I do little C/C++ but this looks
> really good)
> Eclipse was quite obnoxious and a hog for anything other than JAVA in my
> experience.
> All of these are in the Ubuntu repos, though for the python editors
> since they're written in python getting newer versions might be worthwhile.
> Enjoy,
> Alex
> On 06/01/2010 08:21 PM, christian.mueller at nvoe.at wrote:
>> Hi, I am also a fan of working in the command line. (vi is one of my friends)
>> I use eclipse which is very powerful. Most of the time I am doing
>> Java, but I also used eclipse for programming python and there is
>> support for C++/C too.
>> Java / python really makes your life easier. The only reason for
>> working with C is performance for image operations, but most of them
>> are already there and bindings for higher level languages are supported.
>> I also use ubuntu 10.04, so try a
>> apt-cache search eclipse
>> to see what is already there.
>> Quoting Zoltan Szecsei <zoltans at geograph.co.za>:
>>> Cross posted with gdal-dev and ossim-developer
>>> Hi Everyone,
>>> Please indulge me in this slightly off topic question.
>>> As I have spent the last many years of my GIS life programming in a
>>> (linux BASH-like) scripting language, I am somewhat out of date with
>>> Linux development environments.
>>> I last programmed many years back, in C using Visual Studio 95 and
>>> "flat C" on Linux command line - no fancy "make" or anything.
>>> I want to migrate my Linux based GIS workflows onto OpenSource
>>> projects, using a mix of gdal/proj4/ossim and maybe GRASS - as the need
>>> and mood grabs me.
>>> I have just loaded Ubuntu 10.04 64 bit as my platform, and ask if
>>> anyone is willing to let me know what development environments they
>>> program in.
>>> I'm looking to write graphical (over orthos/satelite images) digitising
>>> routines, ie: display/edit/capture vectors on/in image windows, catch
>>> mouse, keyboard and maybe joystick events. Maybe even stereo (3D)
>>> capture too.
>>> I am not a fan of GUI data capture, so whilst this looks much like
>>> reinventing the wheel, I don't think it is, and hence I am unlikely to
>>> see the benefit of "tacking onto" projects like QGIS etc.
>>> I'd be grateful to know what you guys use for programming. (I'll
>>> probably stick with C as I have no experience with Java, Python or
>>> other languages).
>>> Thanks in advance,
>>> Zoltan
> www.ossim.org
> Ossim-developer mailing list
> Ossim-developer at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/ossim-developer
