[gdal-dev] Compiling GDAL --with-oci
Iván Sánchez Ortega
ivan at sanchezortega.es
Fri Jun 4 04:37:59 EDT 2010
Hi all,
I'm trying to compile GDAL with Oracle support.
I'm using a Debian box, with the "oracle-xe-client" package installed
from the Oracle repo ("deb http://oss.oracle.com/debian unstable main
non-free"). Version is 10.2.0.
The GDAL source files are a fresh SVN checkout from two days ago.
The problem:
Running "./configure --with-oci" results in the following:
checking for Oracle OCI headers in
/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/rdbms/public...
header not found
However, that directory (which is inside $ORACLE_HOME) does indeed
contain headers:
ivan at debian:/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/rdbms/public$
ls -l
total 1460
-rw-r--r-- 1 oracle dba 33230 feb 24 2006 nzerror.h
-rw-r--r-- 1 oracle dba 85310 feb 24 2006 nzt.h
-rw-r--r-- 1 oracle dba 11600 feb 24 2006 occiAQ.h
-rw-r--r-- 1 oracle dba 38630 feb 24 2006 occiCommon.h
(etc)
What should I do now? Does GDAL not support linking against Oracle 10.2.0?
Best,
Iván Sánchez Ortega <ivan at sanchezortega.es>
