[gdal-dev] Compiling GDAL --with-oci
Mateusz Loskot
mateusz at loskot.net
Fri Jun 4 04:46:35 EDT 2010
On 04/06/10 09:37, Iván Sánchez Ortega wrote:
> The problem:
> Running "./configure --with-oci" results in the following:
> checking for Oracle OCI headers in
> /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/rdbms/public...
> header not found
> However, that directory (which is inside $ORACLE_HOME) does indeed
> contain headers:
> ivan at debian:/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/rdbms/public$
> ls -l
> total 1460
> -rw-r--r-- 1 oracle dba 33230 feb 24 2006 nzerror.h
> -rw-r--r-- 1 oracle dba 85310 feb 24 2006 nzt.h
> -rw-r--r-- 1 oracle dba 11600 feb 24 2006 occiAQ.h
> -rw-r--r-- 1 oracle dba 38630 feb 24 2006 occiCommon.h
> (etc)
> What should I do now?
Could you please open config.log generated by ./configure and locate
bits related to "Oracle OCI" detection. You should see some
diagnostics indicating what's possible problem.
Then copy & post relevant parts of the log here.
It should help to find what's the problem.
p.s. I'm leaving for the weekend and if nobody is able to take
care of this issue, I will do it when I'm back on Monday.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
