[gdal-dev] problem on function "OGR_FD_GetName"
randy randyqiuxy at hotmail.com
Thu Jun 17 04:21:35 EDT 2010
Hi Peter,
Thanks for your response!
>     I do not use s57 data, however I have written a number of programs which use
> OGR_FD_GetName ... and it has always returned the feature name, if set, or null
> for me.  Feature, as opposed to Layer, names seem quite uncommon, however;
> although I generally set feature names when creating data objects, I have rarely
> encountered them on input from other sources.  I have never investigated whether
> this is a failure in OGR to transmit the name or whether my presumption that
> there was no name to transmit is correct.
My problem is a little odd. In my Ubuntu9.04 OS,my application works well, however,
in my new 10.04 LTS OS, I rebuilt GDAL and my application,then it refused to work.
 So in my last e-mail,I asked Chaitanya whether the environment variable did anything bad.
> I'm not sure how much that helps,
Yes,I appreciate anything you said above including experience,suggestion...
Best regards,
Randy
